01-01-2020 #4
Yes, it's in Motor tuning. Make sure you click the Axis selection on right before making any changes and save when finished.
However, if the settings are identical it could be the Step pulse rising edge for the X-axis drive is on the wrong side. If the Step pulse is firing wrong you will lose 1 step with every direction change.
The way to test for this is to write some G-code which makes lots of A to B moves and back to A. 200 or 300 short moves will do it IE:
G0 x10
x2
x10
etc, etc just copy paste 2 lines above finishing with.
x0
m30
Then Zero Axis and make a Mark, set the code running and when it's finished it should return back to Zero and the mark. If it doesn't return to the mark your Step pulse needs changing.
To do this go into Motor Outputs and change the Active Hi/Lo for the Step pulse.
Only do this if it doesn't return to mark.
Check all axis this way if unsure.
New build (my first) can't draw circles.
By mcyoung in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 29-06-2015, 11:22 AM -
Major issue with snapping to circles -Autocad 2013
By craigrobbo in forum AutoCADReplies: 8Last Post: 01-02-2014, 09:33 AM -
Sometimes Engineer's Squares aren't
By routercnc in forum Tool & Tooling TechnologyReplies: 7Last Post: 25-07-2010, 09:59 PM -
Getting dizzy cutting circles!
By fasteddy in forum Programmers CornerReplies: 19Last Post: 16-05-2010, 07:46 AM
