Thread: Laptop for connecting to CNC?
13-01-2020 #13
We all love a good spat once in a while ;)
I believe there are three UCCNC compatible ethernet controllers; the AXBB-E, the UC300eth, and the UC400eth. For a simple build, I'd recommend the AXBB-E. The other two require a little bit more involved wiring and usually need a breakout board to go with them, whereas the AXBB-E takes care of all that for you, so you just plug stuff into it and off you go.
Yes, the licence is linked to the S/N of the controller - but wait! I don't think you've got the whole picture. The licence is for the software (UCCNC) to talk to the controller - but you don't have to use their software, these boards are also compatible with Mach3 and Mach4 (but not, so far as I can tell, LinuxCNC). There is nothing to stop you using the other software - the licence key just activates THEIR software (UCCNC) for YOUR device (UC100). Its in this format so that people who run multiple machines have to purchase a licence for each machine (which I think is fair enough).
The kicker is that Mach3 or Mach4 also needs a paid licence - and its substantially more than the cost of the UCCNC licence (£200 or £300 vs £60 if I recall correctly?). There is also the consideration that UCCNC has a very good reputation at the moment, and there is a reasonable number of people swapping over to it.
help connecting a pot to huanyang vfd 2.2
By edgas10 in forum General ElectronicsReplies: 15Last Post: 14-08-2016, 06:45 PM -
Connecting 2.2kw vfd to Mains supply
By the great waldo in forum Spindles & Drive MotorsReplies: 20Last Post: 26-05-2016, 09:39 PM -
Connecting power supply for 220v
By Noplace in forum General ElectronicsReplies: 8Last Post: 10-02-2015, 08:34 PM -
Connecting VFD
By andrew583 in forum Spindles & Drive MotorsReplies: 0Last Post: 19-08-2014, 01:01 AM -
connecting stepper driver to PC
By berkut in forum General ElectronicsReplies: 2Last Post: 10-06-2009, 09:25 PM
