    I'm trying to recommision my Syil SX3 after a long period of no use & I'm experiencing an intermittant fault LED on the Z axis stepper driver.
    Before getting too technical, I have a spare stepper driver for the 4th axis which I will swap over but I was wondering if the fault could lie elsewhere & something is feeding back to the stepper driver?
    Was the machine simply switched off and left unused or was move into storage ?
    If its been stored in cold damp conditions
    check the wiring for damage and connectors and Z axis stepper motor for corrosion
    what's the stepper driver part number ?
    first I would search for the stepper driver data to see what the fault LED could be indicating
    ( motor stall , over temperature , internal driver fault ? )
    once your sure the wiring is OK
    I would try connecting the Z axis motor to the spare driver
    John
    Quote Originally Posted by john swift View Post
    John
    Sorted now thx. Simple job to swap wiring over to the 4th axis driver but required a small child contortionist to get access back of the machine :-)
    AFAIK the stepper driver is proprietry Syil, attached is Syils PDF& if I cannot source one do you know of any options?CNC_stepper_driver.pdf
    for some reason apart from the photo on page 1 the pages in th syil manual are blank !
    The photo of the driver reminds me of the Leadshine drivers usd by Tormach
    the Tormach driver having a 10 pin box header instead of the usual 6 way connector for the step , direction and enable inputs
    https://www.cnczone.com/forums/torma...r-pinouts.html
Name:	Tormach Micro Step Driver 31234 B V2.jpg
    John
    Quote Originally Posted by chas-SX3 View Post
    I have three of them doing nothing but sitting in a drawer - I live in Cropwell Bishop, PM me if you want one or all of them. BTW they are Tonman drivers and obsolete.
    Oooh, yes please. Are they off a Syil SX3 ???
    I'm only 20mls away so I could pick them up anytime. How £much do you want?
    PM sent
  1. WANTED: Conqueror Design stepper driver or stepper conversion board
    By pistolknight in forum Items Wanted
    Last Post: 25-05-2019, 11:57 AM
  2. How do I wire a stepper driver to a stepper motor?
    By swood1 in forum Stepper & Servo Motors
    Last Post: 21-09-2014, 05:40 PM
  3. Replies: 1
  4. best stepper driver???????
    By Ross77 in forum Motor Drivers & Controllers
    Last Post: 21-04-2013, 05:05 PM
  5. Which stepper driver
    By Colin Barron in forum Motor Drivers & Controllers
    Last Post: 25-09-2010, 08:33 PM
