Thread: Sent lathe back
10-01-2020 #1
Hi all
Well the Warco I purchased has gone back, I thought I would buy direct from Warco (used) because the website said that the second hand lathes were fully serviced and come with a six month warranty.
Well the lathe turned up 350’ backlash on cross feed, quite a bit of backlash on line feed, cable flange broken so cable was rubbing on metal, they said it must have serviced as it had a new circuit board.
Anyway they sent out a recon cross feed and I fitted it also fitted a new cable flange because I was not plugging it in without, fired it up all seemed ok until I started to turn a bit of bright mild steel it lasted 7 or 8 minutes then a clunk motor still running but not chuck,I had had enough told them to collect it and refund my money.
It took two weeks to get my money back but I got it.
As I still needed a small lathe and as I am only mainly going to be making small parts in brass I did a lot of research and started looking at EMCO Unimat but like most thing’s reviews were good and bad but what I did find out was that Unimat gradually got worse quality with each upgrade so although parts are a bit of a problem I have plumped for a very early EMCO Unimat SL complete with powered mill.Old man but still learning
Bring Back "Back of a Fag Packet" Designs
By magicniner in forum General DiscussionReplies: 9Last Post: 19-04-2016, 09:49 AM -
How would you fasten back to back carriages?
By CharlieRam in forum Rails, Guideways & BearingsReplies: 10Last Post: 04-09-2014, 11:01 PM -
NEW MEMBER: Getting back into it...
By mozzbo in forum New Member IntroductionsReplies: 0Last Post: 30-04-2014, 08:47 PM -
angular contact bearings - back to back, further apart
By dsc in forum Linear & Rotary MotionReplies: 16Last Post: 05-01-2014, 10:59 PM -
Hi All, I'm back!
By irving2008 in forum General DiscussionReplies: 6Last Post: 11-04-2012, 10:01 PM
