    Quote Originally Posted by routerdriver View Post
    Machining 100mm blanks might be an interesting challenge.First you need to find long cutters and then you need to be sure of getting them to and from the workpiece without digging a trench.
    Not with the right spindle and design of the gantry / Z-axis. All the machines I build at this size will cut 100mm depth and retract the tool above the workpiece. However, The cutters are expensive and not easy to find. Work holding also becomes a fun challenge.!
    That is an unusual amount of Z axis travel and really useful when you find a taller job that needs doing.I have had to work on 70mm thick jobs on a machine with 85mm of Z travel and it was quite,er absorbing.The comment about work holding is actually something that needs to be brought into this discussion; T slots in the table,threaded inserts or a vacuum system could all come into play.
  1. Seek advice on which small quality router to buy/build ...
    By evalon in forum Gantry/Router Machines & Building
    Last Post: 06-02-2017, 08:06 AM
  2. Replies: 4
  3. Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
    By Wejjmeister in forum Gantry/Router Machines & Building
    Last Post: 03-01-2016, 12:45 AM
  4. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  5. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
