    Hello there,
    I've been offered a second hand Isel cpm 2018 machine for 1000£ plus shipping, including the spindle a new open sourced control board and some end mill bits.
    Is this price fair?
    Kind regards
    Impossible to say without seeing the machine and more information.
    Is it working or does it just come with a Random control board and spindle which are off the machine.? If so these may not be what you require to get the machine working.
    If it's fully working and it's not worn out then £1000 euros doesn't sound too expensive. But if it's not working then you need to know what will be required to make it work. In this case I'd be more a little less inclined to buy it.
    it's supposed to be fully functional, no more work needed.
  5. #4
    Quote Originally Posted by vimes1984 View Post
    I which case if it suits your needs then I'd buy it because £1000 euros won't get you anything better even if you build it your self.
  7. #5
    is the isel cpm 2018 a good machine? I'm new to this.
  8. #6
    It's an Ok machine that comes with square type linear rails and ball screws which are good to have. It's compact and self-contained in a steel enclosure which is good if you need a clean work area.
    It's designed for schools and making small parts from softer materials. It's not the most powerful machine in the world but it's one of the best in this class at this size machine. Isel are considered a good manufacturer.
  9. The Following User Says Thank You to JAZZCNC For This Useful Post:
  10. #7
    YOu said softer materials, will it tackle Aluminium ?
  11. #8
    Yes with the right cutters and light cuts.
  12. The Following User Says Thank You to JAZZCNC For This Useful Post:
  13. #9
    Doddy's Avatar
    I assume that Vimes (TP reference?) - you've read the equipment specification? In particular examine the work volume (200x175x90) and factor in any clamps/vice etc to understand if that volume is sufficient. It's not /that/ bad, but it is likely to be one of the constraints that you'll hit first.
  14. #10
    I would say that's a fair deal if it'll do what you want workpiece size-wise. A good buddy of mine who got me interested in CNC has a larger Isel machine he uses for making guitars; it's well made and has given something like 20 years good service still maintaining accuracy.
  1. Isel CPM 2018 or Unimatic Educam 20
    By Steve-m in forum Milling Machines, Builds & Conversions
    Last Post: 27-08-2021, 09:39 AM
  2. Unimatic eduCam 20 Pro Driver Software
    By Widowmaker in forum Machine Discussion
    Last Post: 24-12-2019, 01:18 PM
  3. FOR SALE: Unimatic EduCam 20 for sale
    By Mal Weightman in forum Items For Sale
    Last Post: 20-10-2018, 05:16 PM
  4. ISEL GFM 4433/ educam 44
    By macomk in forum Machine Discussion
    Last Post: 18-06-2013, 10:01 PM
  5. diy cnc engraving machine fair price?
    By diy-john in forum Gantry/Router Machines & Building
    Last Post: 09-03-2011, 01:24 PM
