Thread: Am I being silly?
15-01-2020 #31
15-01-2020 #32
15-01-2020 #33
16-01-2020 #34
I used 20mm fully supported rails as they are cheaper and much more tolerant of alignment errors than Hi-Win. Despite coming off the tip the 65mm box section steel the long axis is mounted on looked flat enough to me and my 1m steel ruler so they are directly mounted onto the metal. The gantry is 2 pieces of 50 x 100 mm box welded together and though the surface seemed much flatter than I would have expected I used epoxy to level the face. Unfortunately this was before I knew about the West Systems 105 resin and 209 hardener combination and my chosen goo was too viscous. The result is probably worse than the underlying metal and will be re-done during planned upgrades later this year once we get into winter and the shed daily maximum temperature drops below 50C.
16-01-2020 #35
16-01-2020 #36
16-01-2020 #37
I can tell you for certain you won't get that, not even for real money!
As I've worked my way through the collection of threads here it's noticeable how many of the serious router builders already have a manual milling machine which they use to good effect when building a CNC router.
Kit
PS. On reflection, a 'machine' that can do anything is called a 'workshop' and contains a variety of tools each designed to do a limited range of tasks well. Building a really good workshop is definitely a project of it's own and can take many years.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
16-01-2020 #38
Yes, I realise that. It has taken years for my workshop to get where it is and in reality it is still a small garage which is already severely lacking in space but still lacking in machine tools. I do have access to a bridgeport mill but it is not practical to use that for regular stuff. Hence the idea of building a small router style machine in a fairly rough and ready way but one that is capable of cutting ally so it can be used to upgrade itself (or, more likely build a better one).
The alternative is to bite the bullet and rationlise my garage so I can fit one of the larger mini-mills, cnc that then think about whether I still want a router style machine.
16-01-2020 #39
One day I'm going to retire to a place where the nearest Bridgeport mill is less than 1300Km away. It won't be for a few years yet I'm afraid. Do the best you can and live with it.
16-01-2020 #40
Z axis playing silly buggers
By cropwell in forum General DiscussionReplies: 6Last Post: 14-01-2017, 12:13 AM -
A silly question on tapped holes
By Philly in forum Tool & Tooling TechnologyReplies: 5Last Post: 11-04-2013, 10:18 PM -
NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
By Simon in forum New Member IntroductionsReplies: 0Last Post: 26-06-2011, 10:02 AM -
NEW MEMBER: Silly high speed lathe.
By rlechem in forum New Member IntroductionsReplies: 1Last Post: 20-07-2009, 11:50 PM
