Thread: Am I being silly?
16-01-2020 #2
I used 20mm fully supported rails as they are cheaper and much more tolerant of alignment errors than Hi-Win. Despite coming off the tip the 65mm box section steel the long axis is mounted on looked flat enough to me and my 1m steel ruler so they are directly mounted onto the metal. The gantry is 2 pieces of 50 x 100 mm box welded together and though the surface seemed much flatter than I would have expected I used epoxy to level the face. Unfortunately this was before I knew about the West Systems 105 resin and 209 hardener combination and my chosen goo was too viscous. The result is probably worse than the underlying metal and will be re-done during planned upgrades later this year once we get into winter and the shed daily maximum temperature drops below 50C.
16-01-2020 #3
Z axis playing silly buggers
By cropwell in forum General DiscussionReplies: 6Last Post: 14-01-2017, 12:13 AM -
A silly question on tapped holes
By Philly in forum Tool & Tooling TechnologyReplies: 5Last Post: 11-04-2013, 10:18 PM -
NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
By Simon in forum New Member IntroductionsReplies: 0Last Post: 26-06-2011, 10:02 AM -
NEW MEMBER: Silly high speed lathe.
By rlechem in forum New Member IntroductionsReplies: 1Last Post: 20-07-2009, 11:50 PM
