28-03-2020 #15
Geoff. Do you have a DVM ? a meter to test the voltage AC and DC . If so can you check what voltage you are getting from each PSU on the DC terminals.
The smaller PSU should be putting out about 12-24V if it is not doing so then you need to check if it is getting 230V AC on the input. There may be a loose connection or a fuse blown.Last edited by Clive S; 28-03-2020 at 10:26 AM.
mach3 won't reset
By dougberrow in forum Artsoft Mach (3 & 4)Replies: 2Last Post: 27-05-2019, 11:25 PM -
Help needed with Mach 3 - reset external flashing light
By Tom J in forum General ElectronicsReplies: 7Last Post: 26-03-2017, 08:34 PM -
Sieg KX1 & Mach3 won't come out of emergency reset
By lateAtNight in forum Gantry/Router Machines & BuildingReplies: 32Last Post: 19-06-2015, 06:37 PM -
Please help me... It wont work.
By kingcreaky in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 22-01-2014, 10:42 PM
