Thread: How to hold perspex flat
17-01-2020 #3
I do these kind of jobs using normally a simple custom for the job vacuum fixture made from wood or plywood. Vacuum seals cut with scissors from 60x40cm EVA rubber sheet found from any asian shop for 60 cents / here in Spain/ .
Or use the thinnest double sided tape and make sure you have tape at the center so the piece will not bend. probably will have to take the protective sheet from the bottom side as this may cause the problems.
0.02mm depth of cut is too small. use spring loaded diamond drag for such jobs, as it gives exactly that depth/ width and is much cleaner from what i see on picture.
Work hold down
By gorbo in forum Woodwork DiscussionReplies: 16Last Post: 27-03-2020, 09:15 AM -
WANTED: Boxford 160 perspex guard
By jetrebel in forum Items WantedReplies: 0Last Post: 24-05-2017, 09:51 PM -
CNC cutting service (acrylic/perspex, mdf, plywood, carbon etc)
By adrpak in forum Manufacturer NewsReplies: 0Last Post: 28-04-2017, 06:38 AM -
Cutting Perspex?
By Shinobiwan in forum Machine DiscussionReplies: 7Last Post: 19-02-2013, 09:25 PM -
Hold down solution
By jonbabbz in forum General DiscussionReplies: 4Last Post: 11-10-2012, 08:21 PM
