Thread: Modifying a 6040 machine
18-01-2020 #1
If I was retro fit dual steppers to the Y Axis of a Chinese 6040 CNC Router, would it be best to keep the Gantry brace that runs under the bed, or is it not required?
Mentioning I would be using extrusion for Gantry instead of the thin plate used now.
Steve
18-01-2020 #2
Either will work fine. I've built machines with both methods and they perform just the same. However, what the cross brace allows you to do is move the ball-screws and motors under the bed out of the way protecting them from debris if you like.
18-01-2020 #3
Thanks Jazz. Good to know one doesnt need to use a bottom plate if using 2 steppers.
A simpler build is good.
Steve
Sent from my SM-G920I using Tapatalk
There are currently 13 users browsing this thread. (0 members and 13 guests)
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
Advice on new set up for 6040 CNC machine
By Cousinit75 in forum Chinese MachinesReplies: 19Last Post: 04-02-2022, 06:48 PM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Machine better than a chinese 6040 for a beginner?
By d4cnc in forum Gantry/Router Machines & BuildingReplies: 21Last Post: 09-11-2015, 12:47 PM -
Newbie question re converting my 6040 machine to use a laser
By GaryWilliams in forum Laser Machines & BuildingReplies: 2Last Post: 19-10-2015, 03:09 PM
