Thread: Cutting Wood veneer
I have used double sided tape to hold perspex and it does work BUT make sure you get the removeable stuff otherwise you will have trouble getting the stuff off the workpiece, you will probably have the same problem with spray adhesive. I would suggest something more rigid than corrugated cardboard as a backing like a piece of plywood (the double sided tape doesn't stick too well on MDF in my experience). If it helps this is what I have been using https://www.ebay.co.uk/itm/25mm-50mm...SFhw74yqXqKGfg
19-01-2020 #2
Just the sort of thing I needed to know :-) I'd thought about corrugated cardboard, because if I couldn't unstick it, I could at least peel off the corrugated bit and leave it stuck to the paper. Really appreciate the tips - my CNC arrives on Thursday, so I'm making plans :-)
Birch plywood and veneer sources ?
By threedee in forum Woodwork DiscussionReplies: 6Last Post: 31-01-2023, 11:08 PM -
cnc crashes when cutting 2D profiles in wood
By chrisobrien07 in forum Woodwork DiscussionReplies: 10Last Post: 16-11-2021, 09:38 PM -
Where to buy plywood veneer in UK?
By carol in forum Woodwork DiscussionReplies: 2Last Post: 14-09-2017, 08:34 PM -
I need a Good CNC Machine for cutting letters out of wood for under 800.00
By theceo in forum Machine DiscussionReplies: 6Last Post: 02-04-2016, 12:48 PM -
Glue for Vacuum Press Veneer?
By Tenson in forum Woodwork DiscussionReplies: 16Last Post: 05-09-2014, 03:42 PM
