  1. #2
    relative advantages and disadvantages of using ethernet Mesa boards - I was thinking of the 7i76e - over PCI based set ups - 5i25 with a 7i76. The former set-up seems more straightforward and more flexible to me, but I'm just wondering if it's more problematic in some way.
    Both of the above will give you the same results. 5i25+7i76 is for pci for the pcix you would use a 6i25+7i76 these two setups require a DB25 cable to connect the two cards together. ie quite a short distance.
    The Ethernet versions means you can have the PC any distance (less than say about 90mtrs) from the control box with a cat5 cable.
    Ethernet versions are 7i76e with spindle control, 7i96 without spindle control ie. no 0-10v, These two cards don't require another BOB.
    Ethernet 7i92 does require another BOB as there are no opto's on it but a cheap bob can be plugged into it.
    I have used all of the above apart from the 6i25.
    If you decide to use servos in the future you can plug another card like a 7i77 for analogue or 7i85 step/dir both with encoder feedback, into any of the above cards.
    Edit: TheLinuxcnc version to go for is 2.8 or 2.9 as 2.7 is getting to EOL and things have changed a bit from 2.7 to 2.8
    Please note Linuxcnc is a learning curve, I am no expert but I have done a few conversions with Lcnc.
  1. FOR SALE: Mesa boards 7i76 5i25 7i73
    By chelseafan5 in forum Items For Sale
    Last Post: 05-02-2018, 01:35 PM
  2. WANTED: Mesa boards, 7i76, 5i25
    By Bally123 in forum Items Wanted
    Last Post: 20-01-2018, 12:29 PM
  3. WANTED: wanted 2 x ethernet smoothstepper boards
    By chelseafan5 in forum Items Wanted
    Last Post: 09-10-2017, 08:38 PM
  4. FOR SALE: Mesa control boards
    By drumsticksplinter in forum Items For Sale
    Last Post: 09-05-2016, 09:02 PM
  5. ebay board kits v 542 boards
    By crossleymarko in forum Motor Drivers & Controllers
    Last Post: 17-04-2012, 08:26 PM
