Thread: Cabling a CNC Router
Maybe I wasn't clear enough above.
The motors are 4.5v, 2.5A per phase to be wired bipolar.
I was originally thinking of wiring them as serial to match the 2.5A controllers, but after reading the other thread it mentioned that you get greater torque if they are wired in parallel - that would, I presume, double the current being drawn from the controller - thus needing a resistor to limit the current (ohms law).
The motors are from Arc Euro Trade - 180Ncm (can be used bipolar or unipolar)
The controllers are the Routout 2.5A ones
The power supply that I currently have to hand is 12-14V (varies a tad under load) @ 10A.
I will get a better PSU at a later date, probably around the 25v mark.
20-10-2009 #2
Its hard to tell as Arc Euro dont say what mode they spec the current in, however the 3.5Nm motor is spec'd as a 4.2A/phase in bipolar parallel and they call that a '4.2A stepper' so I am guessing that yours is a 2.5A bipolar parallel. the way to check this is measure the resistance of one winding e.g. red to yellow - if it's 4ohm then you can run this bipolar parallel at 2.5A.
Whatever the motor spec' if you only have 12v power supply then I'd run this bipolar parallel at 2.5A. Bipolar series on only 12v is going to be very underpowered.
You don't need a current limiting resistor, the Routout drivers are chopper current limiting drivers... they wont let you draw more than the preset current limit (up to a maximum of 2.5A).
20-10-2009 #3
Thanks for that.
What about for the 25v scenario?
20-10-2009 #4
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM -
Metal shielded cabling
By alanb in forum General ElectronicsReplies: 4Last Post: 07-02-2010, 11:07 PM
