Thread: Technician required
21-01-2020 #1
Hi
I have a Gerber Dimension that has been running in its original format. I bought this machine to learn on and use for low volume work. However, the operating system is incredibly slow and now is on the blink.
Rather than throw money at the archaic omega system, I would like to update it to take mach3. I’m aware that steppers and ‘stuff’ will need to be replaced but I’m really not the person to do this, hence my cry for help
Does anyone know of any techies based in the Surrey area that might be able to assist?
TIA.
Tony
15-03-2020 #2
Tony did you find a techie as I am looking for one let me know if you find one
Joss
16-03-2020 #3
Hi Joss
No, not one response
16-03-2020 #4
I think I am going to look in to a career change
16-03-2020 #5
It's DIY or a lot of money, I think it's also a job for which you would need to deliver your machine to the workshop of the "technician" doing the job, it's not something I'd consider away from my own workshop.
Converting for money is only really worth the time for yourself or if you buy or build the machine to be converted and sell it finished, I learned enough to do this from zero CNC experience when almost 50, it's not rocket surgery, it just takes commitment and motivation ;-)You think that's too expensive? You're not a Model Engineer are you? :D
16-03-2020 #6
No not a model engineer this is a 3 phase stone engraving machine that in daily use this is not a hobby it my profession that why I need a tech at the workshop
16-03-2020 #7
You have mistaken my signature for part of my post, my signature refers to the long pockets and short arms usually associated with model engineers in the UK! :D
Unless you stick your fingers into live components 3 phase is no scarier to deal with than single phase, (even with single phase it's still unwise to stick your fingers into live components) provided you work to the correct standards, which are freely available.
3 phase isn't magic or complicated but for anyone not wanting to learn my point is that for the competence you require you should expect to pay close to the price of a working machine or more, to get your machine working if someone is to come to you.You think that's too expensive? You're not a Model Engineer are you? :D
16-03-2020 #8
16-03-2020 #9
16-03-2020 #10
Technician required
By joss01 in forum General DiscussionReplies: 30Last Post: 16-03-2020, 08:19 PM -
Opportunity for CAD/CAM Workshop Engineer/Technician in London at Med Tech Startup
By aot in forum Opportunities Available & SoughtReplies: 0Last Post: 25-01-2016, 11:46 AM -
CNC Maintenance Technician Job Opportunity - SeaStar Solutions, Richmond, BC, Canada
By Etranhirose in forum Opportunities Available & SoughtReplies: 0Last Post: 10-09-2015, 12:35 AM -
NEW MEMBER: Technician, secondary education
By Nic in forum New Member IntroductionsReplies: 0Last Post: 22-07-2011, 12:34 PM -
Maintenance Technician/Engineer
By mvolt in forum Opportunities Available & SoughtReplies: 0Last Post: 16-02-2011, 10:38 AM
