Thread: AXBB-E licence key problem
22-01-2020 #4
Then I think the problem may be a connection issue rather than license issue? Might be worth removing that switch in the shortcut to test. I'd then double check the ethernet adapter settings against the manual, and ensure you have packets being sent and received. If you're sending but getting nothing back make sure the firewall is disabled then retry.
AXBB charge pump fault
By CharlieRam in forum CNCdrive (UC100, UC300ETH)Replies: 78Last Post: 18-07-2021, 08:31 PM -
Help needed to connect my VFD to the AXBB controller
By CharlieRam in forum Spindles & Drive MotorsReplies: 24Last Post: 23-09-2020, 12:10 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Mach 3 new licence, now reset not working..
By Fastesteddy in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 13-07-2018, 07:57 PM -
Mach3 licence
By Duffman in forum Artsoft Mach (3 & 4)Replies: 10Last Post: 22-07-2017, 06:47 PM
