24-01-2020 #1
Hello All
What would be the preferred material for a control box steel or plastic. I assume the screening would be better on a steel enclosure although working plastic would be easier and I had thought of lining a plastic box with some thickish self adhesive aluminium foil that I have for screening. Any opinions on the subject ?
cheers
Andrew
24-01-2020 #2
Plastic or Metal makes no difference really. What is important is the grounding is correct. Use a Star ground system so all shields and grounds go back to one point and you won't have any issues. Also, it's good wiring practise to route any signal wires as far away from high voltage wires as possible. Obviously it's not always possible to do this so some signal and high voltage wires will run side by side, in this case, don't tie wrap them together.
24-01-2020 #3
Enclosure Recommendations
By Washout in forum Control Hardware & SystemsReplies: 1Last Post: 20-05-2021, 12:45 PM -
Control enclosure size
By chillybo in forum General DiscussionReplies: 18Last Post: 22-12-2019, 01:57 PM -
CNC router enclosure
By Leadhead in forum Workshop & EquipmentReplies: 2Last Post: 03-05-2018, 11:00 PM -
Help on building an enclosure
By thomashomer1986 in forum General ElectronicsReplies: 12Last Post: 02-02-2014, 06:38 PM -
PCB enclosure ?
By manofgresley in forum Electronic Project BuildingReplies: 15Last Post: 10-08-2012, 11:47 AM
