25-01-2020 #2
just so you know this is what I am using in my system and as you can see its not expensive
https://www.ebay.co.uk/itm/10-in-lin...EAAOSw~vNcBnGQ
but I do like your complete system and if in had the time and ability I would build something like that
25-01-2020 #3
That's a good idea - much cheaper than anything I've seen from pneumatics suppliers. Even so the independent pump approach is better for me as it means I can use a wee side channel blower I have here for the air. It only does 5psi, but when I tried it a few minutes ago it scattered chips over 2m from the pillar drill
25-01-2020 #4
Not pressurized , can be placed almost anywhere, 25ltr drum on the floor if you like
Ethanol mist for cutting aluminium
By matt-b2 in forum Swarf & Chip ManagementReplies: 60Last Post: 15-08-2021, 11:05 AM -
Mist Coolant Project
By magicniner in forum Swarf & Chip ManagementReplies: 10Last Post: 06-11-2018, 09:39 PM -
Schneider Altivar 320 wiring / setup help needed
By TadasM in forum Spindles & Drive MotorsReplies: 31Last Post: 21-10-2016, 07:43 AM -
WANTED: Mist lubrication system
By badgerman in forum Items WantedReplies: 9Last Post: 21-08-2014, 12:28 AM -
i7 Water cooling system
By Jonathan in forum Metalwork Project ShowcaseReplies: 19Last Post: 01-01-2012, 06:27 PM
