    I have done the same type of setup as boyan with the filter housing etc. Im running it at 15psi with thin cutting oil and that works well. I have an 8cfm compressor with 100 litre tank that keeps up fine. The thinner the cooling medium the less pressure you will need to move it.
    Quote Originally Posted by johngoodrich View Post
    Thanks for that John, v.useful. 8cfm is not a lot, I won't need to use the big (and noisy) machine for that
  1. Ethanol mist for cutting aluminium
    By matt-b2 in forum Swarf & Chip Management
    Last Post: 15-08-2021, 11:05 AM
  2. Mist Coolant Project
    By magicniner in forum Swarf & Chip Management
    Last Post: 06-11-2018, 09:39 PM
  3. Schneider Altivar 320 wiring / setup help needed
    By TadasM in forum Spindles & Drive Motors
    Last Post: 21-10-2016, 07:43 AM
  4. WANTED: Mist lubrication system
    By badgerman in forum Items Wanted
    Last Post: 21-08-2014, 12:28 AM
  5. i7 Water cooling system
    By Jonathan in forum Metalwork Project Showcase
    Last Post: 01-01-2012, 06:27 PM
