  1. #2
    Quote Originally Posted by joe.ninety View Post
    1. What is the maximum cutting area I can expect to have if I don't want to have a Y axis that has dual steppers? I hope that's the correct way to phrase the question, from my basic understanding once you get past a certain size I thought the Y axis needs two linked/synced steppers?
    For a router cutting mostly wood, plastics and the occasional bit of light aluminum work then wouldn't go past 700mm cutting width with a single screw. However, the gantry design comes into play as well and needs to be built a little stronger as you get wider.
    2. What size profiles would I likely be looking at if I wanted to build a machine chassis to the above requirements... 4080, 4590, 5050 etc, etc.
    I appreciate that the last question might be quantified by other design considerations, but again just wonder what people would consider the minimum sized profile to guarantee a decent base level of rigidity.
    45x90 or 40x80 is a minimum I would use and again depends on the machine size and design. To give you some idea this machine design I build use's only 45x90 and it will happily cut everything up to aluminium.
    The machine in the picture uses a single screw and as a cutting area of about 600 x 1000 if I recall correctly. However, I've built lots of machines with this design up to 700 x 1250 cutting area using single screws. If you wanted stronger machine at the same width/length say for cutting mostly aluminum or Hardwoods with heavy cuts then go with twin motors every time.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. NEW MEMBER: Hi and a couple of questions.
    By TheBoltonian in forum New Member Introductions
    Last Post: 08-01-2017, 05:58 PM
  2. Replies: 0
    Last Post: 29-11-2016, 02:16 PM
  3. hi all, new to cnc building,couple of questions if anyone can help. TIA
    By universally in forum Gantry/Router Machines & Building
    Last Post: 18-01-2015, 04:12 PM
  4. Beginner MYCNCDIY Mill Build questions
    By suraj1793 in forum Gantry/Router Machines & Building
    Last Post: 15-11-2014, 06:28 PM
  5. NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
    By m0nk3hjam in forum New Member Introductions
    Last Post: 17-08-2010, 02:32 AM
