  1. #7
    The axes are defined with you standing how you would actually use the machine.
    Side to side is X. X+ is the cutter moving to the right. Towards you and away from you is Y. Y+ is the cutter moving away from you. Up and down is Z. Z+ is cutter moving up.
    This is a simple convention from drawing. The same as graphs. It is used in virtually all drawing/CAD/machines.
    Unfortunately a lot of hobbyists can't understand the convention and insist on called the axis across the gantry Y or some other variation.
    For instance on my machine:
    Working area 1300x675mm.
    Gantry is the long axis.
    X runs across the gantry, 1300mm.
    X is not necessarily the longest axis. X is not necessarily the lowest/bottom axis. E.g. X is on top of Y in my machine.
  2. The Following User Says Thank You to pippin88 For This Useful Post:
  1. NEW MEMBER: Hi and a couple of questions.
    By TheBoltonian in forum New Member Introductions
    Last Post: 08-01-2017, 05:58 PM
  2. Replies: 0
    Last Post: 29-11-2016, 02:16 PM
  3. hi all, new to cnc building,couple of questions if anyone can help. TIA
    By universally in forum Gantry/Router Machines & Building
    Last Post: 18-01-2015, 04:12 PM
  4. Beginner MYCNCDIY Mill Build questions
    By suraj1793 in forum Gantry/Router Machines & Building
    Last Post: 15-11-2014, 06:28 PM
  5. NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
    By m0nk3hjam in forum New Member Introductions
    Last Post: 17-08-2010, 02:32 AM
