Interesting point. If I'm using something like Vectric Vcarve (which I do from time to time - great for text/signboard type applications) then it makes sense to align the landscape screen and the landscape machine orientation. However, using Fusion 360 (which I do a lot these days) then I'm often building up an assembly as part of the 3D model on screen, but picking out individual components for CAM/toolpath generation. It might well be that the alignment of an individual component is not naturally laid out appropriately. For example, the base of the component which would sit on the bed of the machine might not even be in the XY plane in the model. F360 allows you to easily select axes for CAM independently of the original model axes so you can just, in effect, rotate the component in 3D to best fit the machine.
If I knew then what I know now, I might well have configured my own machine to have X running left to right in front of me - the conventional XY layout - even though the machine would then be portrait rather than landscape. Main thing is to understand what you are doing!
27-01-2020 #2
It's always better to have it setup up in the direction you view the machine. It doesn't really matter whether X runs across gantry or down machines length but it should always run left to right as you view machine and in a positive direction like the cartesian coordinate system does. Y should always run away and towards you, again positive direction moving away from you. Otherwise, it gets confusing quickly.
NEW MEMBER: Hi and a couple of questions.
By TheBoltonian in forum New Member IntroductionsReplies: 4Last Post: 08-01-2017, 05:58 PM -
WANTED: Supported rail - a couple of lengths of any size for an experiment!
By GND in forum Items WantedReplies: 0Last Post: 29-11-2016, 02:16 PM -
hi all, new to cnc building,couple of questions if anyone can help. TIA
By universally in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 18-01-2015, 04:12 PM -
Beginner MYCNCDIY Mill Build questions
By suraj1793 in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 15-11-2014, 06:28 PM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM
