    I have a Harrison Alpha 330s plus lathe with Fanuc controller and have been trying to do a sram back up as per the FANUC instructions. It all goes ok until it asks me to back up sram data.... it asks gor "Yes or no", when I hit the soft key yes nothing happens! I have tried different cards but with no luck. All these cards do however work with the machine when reading and copying program files to the machines memory. Also is the machine will not complete a format of any of these cards, it will continually just flash "formatting" and not complete! I was however able to format them successfully fat on my laptop. I'm a bit stuck now as I'd like to back the machine up but it's just not working! Any suggestions appreciated.
    Which Fanuc controller is it.? Do you have the operators manual for it. Would be worth checking out if it's got a write-protect so cannot accidentally overwrite or format cards.
    Its the 21iT lathe version I think, Ive got the manual, I enabled parameter changes to allow me to change i/o to 4 to read the card but do you think there might be another parameter to change to allow the sram backup and format, ie allowing writing to the card....hadnt thought of that
    Hi, I have the same lathe with the same problem, did you get anywhere with this?
    No, not resolved pitmole.....and seeing you have the same machine are the your workoffsets activated ie G54 etc activated, I have only a workshift button. Thanks
    Hi, I honestly cant remember about the soft key, and am away from my machine till end of next week, will look for you then, mostly used it in conversational mode TBH which it is pretty good at!
    Hi all, I also work in a shop with an Alpha 330-s. I have the programming manual, but no machine / maintenance manual. Is there anybody that can help get me a copy.
    I also would like to do a backup of parameters 'just in-case', can anyone advise on the method, and type of "SRAM" card that is being used?
    Thank you.
    So you go into boot menu
    Then it stops working on SRAM ?
    Can you back up the pmc file
    What manuals are you after
    Quote Originally Posted by kyledsmith87 View Post
    Thank you.
    Hi. can you please send me the manuals and parameter backup if you have. It would be a great help.
    Hi does anyone have a parameter backup for a Alpha 330S plus. Just got one, and the parameters were lost before I could back them up. My current dilemma is parameters 2084 X&Z and 2085 X&Z!
    Thank you in advance
    SN: S20125
    Year 2001
  1. Sent lathe back
    By Dell in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 10-01-2020, 06:19 PM
  2. Replies: 0
    Last Post: 15-12-2019, 09:44 PM
  3. WANTED: Harrison Alpha 330 or M300 converted to CNC, any condition.
    By mitip in forum Items Wanted
    Last Post: 09-05-2019, 02:55 PM
  4. Replacement motor choice for SEM servos on a Harrison M300 lathe
    By PeteL in forum Stepper & Servo Motors
    Last Post: 03-05-2016, 07:05 PM
  5. Harrison Trainer 280 CNC lathe
    By markems0 in forum Milling Machines, Builds & Conversions
    Last Post: 25-08-2010, 12:17 PM
