30-01-2020 #1What you basically must NOT do is put any form of switch between the VFD and the three motor cables going to the spindle or unplug the spindle with the VFD running.surprised me when I read the manual and it clearly says to NOT use a contactor or it could damage the VFD. I’d watched people on YouTube use contactors in their build and would have made a big mistake if I hadn’t looked at the manual.
If you do you might hear a big bang...Clive
30-01-2020 #2
Double up on that several times over!! NOTHING should come between the VFD and the spindle. Only ever use the spindle ON/OFF control wiring to stop the spindle if you ever want it to start again. I wouldn't even cut the mains input to the VFD with the spindle running, though that might be my clinical anxiety kicking in
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
30-01-2020 #3
While this excellent and sound advice, It isn't exactly correct.? . . . It's true that you shouldn't control the spindle ON/OFF with a Contactor between VFD and Spindle or use anything that will interrupt the connection while running, however, you can safely have a contactor between them provide it is not switched while the VFD is running.
I've done this before to control multiple spindles with single VFD but there must be safety involved and interlocks checking the spindle as stopped spinning and the RUN command isn't active before allowing it to happen.
This said the advice above is good.
30-01-2020 #4
30-01-2020 #5
The only fan is inside the VFD to cool the electronics, the spindle doesn't have any fans. Some Vfd's the fan only comes on when VFD is running whatever is connected, some come on at power-up and stay on. The huanyang VFD is on all the time. (That said some Huanyang models do have load driven fans but can't remember the model #)
Only need a braking resistor if you want to use DC braking to stop heavier loads. For the most part, provided you don't have the Spindle de-acceleration time too short and not using heavy or wide tooling then won't need a resistor.
31-01-2020 #6
3040Z machine spindle upgrade/modification
By enterpryse in forum Chinese MachinesReplies: 13Last Post: 15-06-2020, 05:54 PM -
Upgrade to 3040T Machine Table/Bed, options?
By davitc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 30-01-2020, 11:57 AM -
Newbie Machine Build Log (Fancy Machine)
By Fancy in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 18-09-2018, 06:15 PM -
Upgrade? Chinese CNC Machine
By Carlb1058 in forum Machine DiscussionReplies: 120Last Post: 15-08-2013, 09:04 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM
