27-01-2020 #2
Yep. That looks OK.
One thing to note is that you may have to change some parameters in the VFD. PD143 is sometimes wrong.
When you have it working if the spindle is running the wrong way. Just change over any two of the spindle wires going to the VFD
This is from the sticky on the forum:-
NOTE: Always check these settings are applicable to your Haunyang VFD as there have been some design variances over the years.
General VFD setup:
Here's the correct settings for the Huanyang VFD that always seems to come with these kits.
PD013 - 8 MASTER RESET <<< DO THIS FIRST [Jonathan Edit: I prefer not to input this reset command, as often they've set a lot of the settings for you, so it saves time to leave it and you'll spot any settings that are wrong when you set the rest, so there's no risk]
PD005 - 400
PD004 - 400
PD003 - 400
PD006 - 2.5
PD007 - 1.20
PD008 - 220
PD009 - 15
PD011 - 120 [Jonathan Edit: No, this is a common misconception. This setting is the lower frequency limit, so setting it to 120Hz means you can't run the spindle below 7200rpm, which originated from the air cooled spindles which would burn out below this speed. This is not a problem with water cooling, so you can set it to zero. You wont get much torque below 7200rpm, but down to about 3200rpm is useable for drilling small holes in aluminum if you don't have carbide drills.]
PD014 - 1 [Jonathan Edit: This is time to accelerate to rated speed. It may be better not to set it as low as 1 second (e.g. 2) to reduce the starting current, or if you don't appreciate the lights dimming every time you press run.]
PD015 - 1
PD072 - 400.00
PD143 - 2
PD142 - 7
PD144 - 3000, factory setting is 1440 ->3000 gives correct RPM of 24000 at 400hz
Control Settings:
For spindle Start/Stop using Mach controlled relay connect DCM to FOR with the relay wired between the two. NOTE: Wiring DCM to REV will give reverse spindle rotation.
For variable speed control using a 10k ohm pot connect ACM and 10v to the pot with IV on the Wiper.
PD001 - 0 = Start from VFD Panel(Manual control), 1 = Control from inputs(use if Mach is start/stopping your spindle as explained above)
PD044 - 2
PD045 - 3..Clive
27-01-2020 #3
Re the VFD setup PD014...
I have mine set quite long as my entire shed, air-con included, runs off a single 16A breaker. It is then necessary to add a delay to the G-code for each job after the spindle start command to allow it time to run up before it starts cutting. I use a 6 second delay (G4 P6).An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
27-01-2020 #4
28-01-2020 #5
3040Z machine spindle upgrade/modification
By enterpryse in forum Chinese MachinesReplies: 13Last Post: 15-06-2020, 05:54 PM -
Upgrade to 3040T Machine Table/Bed, options?
By davitc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 30-01-2020, 11:57 AM -
Newbie Machine Build Log (Fancy Machine)
By Fancy in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 18-09-2018, 06:15 PM -
Upgrade? Chinese CNC Machine
By Carlb1058 in forum Machine DiscussionReplies: 120Last Post: 15-08-2013, 09:04 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM
