30-01-2020 #2
If I'd been an avid reader of MYCNCUK before I ever set out to build my first plywood and allthread router a few years ago, the machine I have now would not look anything like the machine I have now!
30-01-2020 #3
30-01-2020 #4
30-01-2020 #5
30-01-2020 #6
31-01-2020 #7
01-02-2020 #8
I’ve got a feeling that he may play Kerbal Space Program. LOL
Back to my “upgrade” I’m abandoning the attemp as upgrading it would need me to replace too much. A friend has said he will help me with the heavy stuff if he can have a go at making stuff with it (which I think is a fair trade).
So it’s actually time to start planning a machine from scratch. Spent today looking through water pump requirements as the advice is all over the shop... “use a pond pump it’s the cheapest”... “Don’t use a pond pump ffs”... use a 12v water cooling pump and use a pc dual radiator”... “don’t use small pumps as they don’t pump enough to get it all through the narrow pipe”...”don’t use PVC pipe, use expensive anti microbial silicon pipe”... and on, and on, and on. Made my head spin.
So once I get my spindle I think I’ll set up a system to test actual flow rate and temp. ... and oh sh1t... we just left the EU. *cry*
01-02-2020 #9
I've probably fitted in excess of 100 of these spindles and everyone used a 24Vdc fish pond or solar panel type pump in sealed 20ltr container that as a head height of around 8mtr with high duty cycle for continuous running. The flow rate doesn't need to be high because the cooling requirements are low.
To be honest these spindles will happily run for 20-30mins without water and not do any damage. My own machine is a basket case of wires n pipes hanging off it from testing and I'm actually just running water straight from the tap through it and out again into the drain because I destroyed the pump while testing a radiator setup.
Most of the jobs I do on this machine are only short jobs 30-40 mins so I hardly ever turn the water on. Only if the job is over an hour-long do I turn it on. It's been this way for the last 3-4yrs without any issues and I nearly exclusively cut aluminum on it. I've also cut a few jobs where I've forgot to turn the water on and only noticed after 2hrs and while the spindle was relatively hot, the spindle didn't complain. They are tuff little things and will stand a lot of abuse regards cooling. My spindle must be 6yrs old now and nobody could abuse it more than I have and do on a weekly basis.
01-02-2020 #10
I went round this loop a few months back, there's a thread on here about it http://www.mycncuk.com/threads/12791...cooled-spindle
The key things I learned are:
Distilled water doesn't go green even after several months in a shed which regularly reaches temperatures approaching 50C.
The diameter of the long runs of PVC pipe makes a huge difference to the flow rate and is more impotant than the size of the pump itself. I used thicker (8mm I think) pipes with short stubs of thinner stuff to connect into the spindle and got double the flow rate.
The head of water also has a big effect on flow rate for these small pumps so you cannot put the water tub on the floor under the machine.
I have no radiator, just a plastic tub full of about 15 litres of distilled water. I don't do and partcularly heavy cutting and there is no signifficant rise in water temperature.
I don't waste time with a pump stop/start control. I use a mains powered submersible aquarium pump which is fed from the same switched mains supply as the VFD. If the VFD is on the pump is runnng which might just improve cooling between jobs.
And one last one to watch out for: If the return pipe falls out of the tub onto the floor all the water can be siphoned out of the tub through the pump even if it's not running!
KISS!
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
3040Z machine spindle upgrade/modification
By enterpryse in forum Chinese MachinesReplies: 13Last Post: 15-06-2020, 05:54 PM -
Upgrade to 3040T Machine Table/Bed, options?
By davitc in forum Gantry/Router Machines & BuildingReplies: 4Last Post: 30-01-2020, 11:57 AM -
Newbie Machine Build Log (Fancy Machine)
By Fancy in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 18-09-2018, 06:15 PM -
Upgrade? Chinese CNC Machine
By Carlb1058 in forum Machine DiscussionReplies: 120Last Post: 15-08-2013, 09:04 AM -
Electronics upgrade for an existing machine.
By Shinobiwan in forum Electronic Project BuildingReplies: 9Last Post: 18-03-2012, 04:01 PM
. There is the answer
