I tried opening your file in Adobe Illustrator but it contains very little... I have attached a screen grab of what it looks like.
As an aside... I have a large vinyl cutter that I use SVG files with, for some reason if I use the 'Export' function in Illustrator to create SVGs, the resulting files do not appear properly in my cutting software (Signworks Pro). If I simply use 'Save as' and elect to save the file as an SVG everything is fine and I can open it and cut with no problems. I'm only telling you this in case the software you are using also gives you 2 ways of creating an SVG... As an export and as a Save As. Maybe try a different way of creating the SVG.
