Difficult to know without seeing the layout of the machine and control box position etc. But If it was me then I would run a single cable from the control box close to the motors and into a terminal box, then split off from there to each motor. This way only got 1 x 2 core wire running through the machine.
You don't really need to be a genius because there are plenty of Cable sizing calculators and web sites explaining correct sizing etc available online if you are unsure. Like this one.
https://www.12voltplanet.co.uk/cable...selection.html
However, 1mm will work fine for your application with short cable lengths.Last edited by JAZZCNC; 31-01-2020 at 04:05 PM.
Help needed to connect my VFD to the AXBB controller
By CharlieRam in forum Spindles & Drive MotorsReplies: 24Last Post: 23-09-2020, 12:10 PM -
UHU Servo Controller build
By Agathon in forum General ElectronicsReplies: 3Last Post: 15-08-2017, 02:45 PM -
op-amp to drive +/-10V analog servo from old +/-5V controller
By paulus.v in forum Motor Drivers & ControllersReplies: 21Last Post: 14-02-2017, 08:33 PM -
servo controller suppliers
By spluppit in forum Motor Drivers & ControllersReplies: 0Last Post: 25-04-2013, 03:02 PM -
By gbar in forum Stepper & Servo MotorsReplies: 4Last Post: 11-05-2012, 12:12 PM
