Thread: Groping my way forward
31-01-2020 #2
You need to use a post processor that is compatible with the machine you are cutting on (if I am reading what the problem is correctly)
If you are using Fusion 360 you should be able to find a PP here ;_
https://cam.autodesk.com/hsmposts
Just ignore this post if you have already done this
31-01-2020 #3
Thank you - I certainly have not done that :-)
31-01-2020 #4
Really helpful, thank you so much - I followed this up - but discovered that there is no PP on the fusion site for USBCNC, but now i knew what I was a looking for and found this - just in case anyone else is looking for this
http://hacknorway.com/wordpress/post.../#comment-3108
I really appreciate your help as it's meant that i think I'm finally getting to where i can use my new CNC machine
31-01-2020 #5
NEW MEMBER: Lurker stepping forward
By Ninjabika in forum New Member IntroductionsReplies: 2Last Post: 30-06-2018, 06:24 PM -
One step forward two back
By gorbo in forum Machine DiscussionReplies: 2Last Post: 12-02-2011, 12:39 PM
