29-01-2020 #1
Well I finally got my servo motors JMC Servo iHSV57-30-18-36-21 180watt connected and working with my AXBB-E . the question I have is which size wire to connect the motors to the controller ? The continuous current rating of the motors is 6 amps I assume the pulse direction wires from the controller board don't have to carry so much current. What dimension wire would be ok for the + - volts Power supply I have is 48volts 16amps and also have a 48v 10 amp supply (both switching) I have read that these servos don't pull much more than 3 amps while running. Should I use just the 16amp supply or go with both? Should I use a separate 2 core wire for the power to the servos and use a thinner screened wire (how thick?) for the signal steps connection. Obviously wire for cable chains would be used. Any ideas gratefully accepted.
Andrew
Help needed to connect my VFD to the AXBB controller
By CharlieRam in forum Spindles & Drive MotorsReplies: 24Last Post: 23-09-2020, 12:10 PM -
UHU Servo Controller build
By Agathon in forum General ElectronicsReplies: 3Last Post: 15-08-2017, 02:45 PM -
op-amp to drive +/-10V analog servo from old +/-5V controller
By paulus.v in forum Motor Drivers & ControllersReplies: 21Last Post: 14-02-2017, 08:33 PM -
servo controller suppliers
By spluppit in forum Motor Drivers & ControllersReplies: 0Last Post: 25-04-2013, 03:02 PM -
By gbar in forum Stepper & Servo MotorsReplies: 4Last Post: 11-05-2012, 12:12 PM
