Page 2 of 2 FirstFirst 12
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 23 Hours Ago Has been a member for 9-10 years. Has a total post count of 300. Received thanks 28 times, giving thanks to others 13 times.
    Quote Originally Posted by ngwagwa View Post
    Well no solution found today.
    Maybe coincidencebut it makes me wonder if something is on it's way out and as it gets hotter it starts failing?
    I.
    Check the cooling fan on the computer chip is clean and working properly
    Phill
    Cheers Phil, fan is in fine fettle - I was thinking it maybe something in the control box that is getting warm.
    So, after reading on the Denford forum that the leadscrew nuts need cleaning every now and then I spent almost all of yesterday cleaning the nuts (without removing them from the lead screws). They were pretty well packed solid with wood/mdf dust and after going through several cans of various degreasers, WD40, PCB cleaner, brake cleaner etc plus a bunch of wooded tooth picks I think I got them prettty clean. A liberal spraying of silcone lubrication and the weird noise had mostly gone so I left the router traversing X,Y and Z for a couple of hours.
    Turned on the machine this morning and all was sweet jogging along to the soft limits several times so set up the datums for the work and set ti cutting. First piece finished n problem but after G55 the position had been lost in X by about 3mm.
    Swapped out the BOB and, there is no other way to describe it, but jogging in all axis the machine sounded sweeter, sort of less strained. Anyway recut the second part followed by the next operation (about an hour each part) with no problem. Have left the machine on the next operation which should finish about 8am in the morning so hopefully all will be well.
    So while the gumed up nuts weren't helping changing the BoB appears to haev been the solution, it may have been a lose wire or a faulty board, don't care as long as it is sorted. Will see in the morning.
  1. Weird Mach3 + CSMIO/IP-M Probe Problem
    By matt-b2 in forum General Discussion
    Last Post: 11-07-2019, 01:05 PM
  2. Weird NC Studio behaviour after manual tool change
    By WRandall in forum Chinese Machines
    Last Post: 27-07-2018, 10:47 AM
  3. Losing steps on Z axis
    By Arzo10 in forum Machine Discussion
    Last Post: 31-03-2017, 10:49 AM
  4. weird z axis..
    By dazza in forum General Discussion
    Last Post: 10-11-2014, 01:39 AM
  5. New Mill losing steps
    By lukecnc2012 in forum Gantry/Router Machines & Building
    Last Post: 08-11-2014, 02:56 PM
