Thread: Centre Drills
    Hi Everyone, Please share some advise.
    Which Centre Drills is good for spotting the location for the drilling operation?
    Neale's Avatar
    Lives in Plymouth, United Kingdom. Last Activity: 2 Weeks Ago Has a total post count of 1,748. Received thanks 299 times, giving thanks to others 11 times.
    I think the answer's in the question! The best form of spotting drill is a spotting drill! Centre drills are intended for drilling holes in the end of a workpiece to take a lathe centre, hence the short projection to clear the point of the centre. Spotting drills are designed specifically for spotting, are much stiffer, less fragile (no delicate tip), and you can get them with angles to match the drills you are using. Plenty around on eBay, etc, or tool supplier of your choice.
  3. The Following User Says Thank You to Neale For This Useful Post:
  1. Startrite and Fobco Drills
    By Tenson in forum Workshop & Equipment
    Last Post: 19-07-2017, 12:37 PM
  2. Runout, HSS drills and dowel holes
    By hoezap in forum Metalwork Discussion
    Last Post: 08-03-2017, 12:36 PM
  3. Morse taper drills
    By John S in forum Marketplace Discussion
    Last Post: 08-05-2013, 07:00 PM
  4. FOR SALE: Mills, Thread Mill, Carbide Drills...
    Last Post: 21-03-2011, 01:47 PM
