Thread: Cutting Acrylic
    Especially with small cutters, you need to cut fast enough to avoid rubbing and have open architecture end mills (like the one for ali - room for the chips to fly out). Single flute seem to work OK.
    The pattern was done with a 10deg 0.2mm engraver DOC 0.2 total depth 0.5mm speed 12,000rpm feed 10mm/sec 66% stepover. I use a spray bottle with 75% deionised water 25% isopropanol and a splash of dishwasher rinse aid to kill surface tension. Lettering was done with a 90deg 4 flute V cutter, similar speeds and feeds, but with a more DOC as the bit is stronger. My general rule of thumb for acrylic and wood is DOC = diameter of cutter.
    Infill is Humbrol enamel.
    Hope this helps.
    I am thinking of making a 'wet bench' so I can pump my cutting fluid over it and recover and re-use it. I will post results if I do it.
    Cheers,
    Rob
ID:	27313 This is the sort of stuff I have been engraving
  1. Advice for cutting acrylic sheet
    By Hillbilly52 in forum Tool & Tooling Technology
    Last Post: 10-08-2018, 11:57 PM
  2. Which cutting tool on acrylic?
    By piper1 in forum Machine Discussion
    Last Post: 06-07-2017, 11:12 PM
  3. Replies: 0
    Last Post: 28-04-2017, 06:38 AM
  4. Acrylic Cutting Help
    By Tenson in forum Machine Discussion
    Last Post: 08-11-2016, 08:15 PM
  5. Laser cutting 10mm acrylic?
    By camhguh in forum Laser Machines & Building
    Last Post: 04-09-2012, 12:51 AM
