07-05-2020 #11
I'm going to answer this Andrew because many won't realize the difference and why it's important, well maybe I should say easier rather than more important.! Ryan might not even realize this yet because it's the first machine he's built.
The Biggest difference is that the 2 plate method doesn't affect the ball screw alignment to adjust the gantry square. However with the single-plate method when you adjust the gantry by loosening the bearing plate you apply a twisting motion on the ball-Nut because the ball-nut mount is attached to the gantry sides which also rotate with the gantry. This puts a bind on the ball-screw so it causes excess wear and lowers the speed.
This then means you have to make adjustments in some other area to bring the ball-screws perpendicular to the gantry sides and parallel to the rails. In a nutshell it's a right pain in the arse.!! . . . The twin plates take all this away.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
600 x 400 Aluminium Profile Gantry Router
By Journeyman in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-03-2016, 04:28 PM -
Initial workpeice tooling set-up instructions using a pendant controller type machine
By Nthkentman in forum Machine DiscussionReplies: 25Last Post: 30-08-2014, 08:33 PM -
aluminium profile for cutting bed of router
By steeplejack in forum Marketplace DiscussionReplies: 3Last Post: 19-10-2013, 10:52 PM -
Some initial questions....
By andy586 in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 27-01-2013, 03:00 PM
