Quote Originally Posted by CNCRY View Post
Hi everyone,
After a couple of months with minimal time to spend on the CNC, finally getting back into it. Learnt lots but still much more to learn, as is always the way..
So one thing I hadn't fully thought out in the design is how to grease the Z bearing blocks. The nipples are in the right place (must avoid obvious jokes here..) but the grease gun "Nozzle" wont fit in the space to engage properly.
So I'm thinking of using the side inlets - only recently realised that was possible.
Hiwin say you should carefully pierce the side inlet with a hot metal rod to avoid chips in the bearings. Do you then have to insert a new grease nipple (can't see a thread) or is there a different type of nozzle available you can just pressure fit and fire in the grease. I can't have a permanent fixing as it would hit the side plate.
Ryan
Did you manage to solve the greasing issue?
Skickat från min SM-A530F via Tapatalk
