    Don't know much about drag engraving but curious about it - does the engraving tip not need to turn to follow the direction of drag? Or is the tip shaped to cut in any direction? Or does it have a swivel in it?
    No.
    Diamond Drag Engraving is entirely unrelated to Drag Knife, the Diamond tip is conical, in no way directional and is not required to rotate at all.
    This is a quick test to ensure it works as designed, lettering is 5mm high
  2. The Following User Says Thank You to magicniner For This Useful Post:
  1. Replies: 0
    Last Post: 15-12-2019, 09:44 PM
  2. work piece showing outside table display
    By terry1956 in forum Artsoft Mach (3 & 4)
    Last Post: 09-01-2017, 10:36 AM
  3. New Table Build, 12x6 work area, drawings up any advice?
  4. Replies: 0
    Last Post: 12-11-2014, 09:14 AM
  5. Setting up work on the rotary table
    Last Post: 09-01-2010, 10:27 AM
