    Hi
    I have a Chinese machine (igolden 3m x 2m), bought 2nd hand which has been running great for the 2 years or so I've had it. It doesn't do a lot of work, maybe only 8 -10 hours a week. However, it recently tripped my electrics half way through a cut and I've been unable to turn it on since without it tripping each time. I've tested my workshop electrics and swapped the isolater with no luck. Has anyone got any experience with these machines and can give any advice as to what to test for/any common problems they might have?
    Russ
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    Easiest option is to start disconnecting things.
    Are there any internal fuses that you could start by disconnecting?
    Also, it would be good if you could post some photos of the control cabinet so we could give better advise.
    Thanks m_c
    Managed to sort it last night.
    I disconnected it and gave the control cabinet a god clean (was quite dusty), reconnected everything and now its back running fine again.
  1. My bulkman workbee cnc machine problems
    By Russell Bates in forum Machine Discussion
    Last Post: 25-07-2022, 11:52 PM
  2. Problems with a new 3040 machine
    By Lennewton in forum Chinese Machines
    Last Post: 03-07-2019, 05:42 PM
  3. Stuga routermaster problems computer dont seem to be connected to machine
    By aled in forum Milling Machines, Builds & Conversions
    Last Post: 16-01-2013, 04:11 PM
  4. Walter Helitronic Power 500, 600 CNC machine wanted.
    By Neil Barks in forum Computer Software
    Last Post: 01-03-2012, 01:56 PM
  5. NEW MEMBER: Beginning machine shop needs help with CNC Step High Z S400 Problems
    By NorthernLightsMachines in forum New Member Introductions
    Last Post: 24-07-2011, 09:41 AM
