You said it all when mentioning the grade. Nobody can tell you what to use without knowing the grade and even then with small cutters, the machine stiffness becomes a large factor.
Unfortunately, it's going to be trial and error. If your machine is stiff enough and the spindle is ok on the runout plus spins fast enough then I can't see why 0.3mm shouldn't be possible with good cooling.
09-02-2020 #2
09-02-2020 #3
Ye, sometimes you just got to be patient and accept it's a slow job. Or you go for it and risk a cutter or two. Me personally if it's just a one-off job then I'd air on the side of caution so don't break cutter but if it's a job I'm going to do regularly then I'd sacrifice a few cutters to find the optimum cutting parameters. It's pays back long term.
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
RFQ: Aluminium parts for mill conversion
By Ross77 in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-01-2015, 12:24 AM -
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
RFQ: Aluminium parts for my first cnc mill.
By everyreasonto in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-07-2011, 11:36 PM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
