You do realize that OA is just bullshit for high helix. All cutters are open architecture.!!
The reason you clagged up was melting because was rubbing rather than cutting because the feed rate was too low. At the lower rpm your not rubbing as much but you still rubbing to some degree which is causing excess wear and a poor finish. It's a common mistake to think melting is because going too fast when it's actually the opposite.
Unfortunately with small tools it's a fine balance between too slow and too fast causing high tool pressure which is what snaps tools. Throw shity material into the mix with it's hard and soft spots plus a slightly wobbly machine and it soon becomes a cluster F'@'K..
Chatter is another problem where going faster can actually reduce chatter by increasing tool pressure which pushes the tool into material harder so reduces chatter. The trick is not overdoing it and lowering the RPM.
09-02-2020 #2
No I didn't realise it was bullshit. I thought it was a combination of a fishtail end and a more open helix. I have found end mills with a flat end are much more prone to clagging.
BTW Sorotec recommend a spindle speed of 50K 7mm/sec feed and 1 or 2mm/sec Z feed for up to 1.2mm cutters. With those parameters I would expect to melt through the metal unless you clear the debris. Chip size must be fine dust.
For 2 and 3mm cutters I use single flute with more success.
09-02-2020 #3
It's mostly down to helix and if polished flutes or not. If you don't need flat bottom cutting then you are always better buying end mills like slot cutters which have more clearence.
For finish passes I actually prefer HSS as the slower feeds n speeds seem to give a better finish.
Yep it requires lots of chip clearing and it does come off like a fine slurry. I recently visited a place in Leeds who engrave and cut with tiny cutters using 100k+ HF spindles and what came off was like a fine grinding paste. Would you believe they hardly break cutters from actually cutting, they break them mostly when replacing or catching on stuff. However, they grind there own so it's no big deal to them.
09-02-2020 #4
Amazing, I visited a place that drilled stainless steel filter discs for a certain phamaceutical company in Nottingham. Their finest holes were much smaller than a human hair and they were using carbide drills on a 1/8 shank. They wouldn't give me info on the feeds and speeds though.
09-02-2020 #5
Yes, these were ground into 4" long 1/8 shank carbide blanks and there most commonly used size was 0.1mm. I could have sat and watched the grinding machine all day it was amazing. Don't think I could have touched the endmills without breaking one so how the hell they get a machine to do it blows my mind.!
solidoworks tapped thread depth and blind hole depth
By reefy86 in forum CAD & CAM SoftwareReplies: 2Last Post: 10-11-2015, 04:14 PM -
RFQ: Aluminium parts for mill conversion
By Ross77 in forum Projects, Jobs & RequestsReplies: 0Last Post: 06-01-2015, 12:24 AM -
WANTED: Engraving Machine to engrave around 0.3mm depth, DXF files on aluminium, anyone?
By stuboy in forum Items WantedReplies: 0Last Post: 05-12-2013, 07:28 PM -
RFQ: Aluminium parts for my first cnc mill.
By everyreasonto in forum Projects, Jobs & RequestsReplies: 0Last Post: 17-07-2011, 11:36 PM -
End mill depth 'stop' rings
By HankMcSpank in forum Tool & Tooling TechnologyReplies: 10Last Post: 24-02-2010, 02:03 AM
