Thread: Quick electronics question
m_c,
I would do it all with a 4066 quad analogue switch. Presuming the '12-24v line' is actually the logic input on the controller for the touch probe, which is resistor strapped high and the probe output is +5v when triggered.
You would use 1/4 of the 4066 to convert the probe output. 1/4 to switch the LED and you have 2 spare to use for other things, like inhibiting the spindle.
The 4066 has an 'on' resistance of about 80ohm (if my memory serves me).
Cheers,
Rob
10-02-2020 #2
Might work but not at 24V... or at least without spilling some smoke. Also CMOS tends to have a high switching voltage at high VSS - the 5V sensor voltage wouldn't cut it at 12V. Max current through a single channel is 10mA so rate the LED resistor accordingly.
Sorry!, not a dig!
OP: Why not use a common ground as a sense input, rather than a 5V input? (if you have 5V handy then ignore)
12-02-2020 #3
Quick question
By jtar40 in forum General ElectronicsReplies: 7Last Post: 07-07-2019, 02:18 PM -
Just starting out - quick question
By glynster in forum Gantry/Router Machines & BuildingReplies: 3Last Post: 06-02-2015, 06:20 PM -
quick question about lead screw
By japcarmaniac in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 09-02-2013, 11:25 PM -
Quick cable question
By PWD in forum General ElectronicsReplies: 18Last Post: 11-12-2012, 09:25 PM -
Quick question
By m.marino in forum General DiscussionReplies: 2Last Post: 18-02-2011, 04:30 PM
