Page 5 of 6 FirstFirst ... 3456 LastLast
  1. #41
    Check out Misumi (massive Japan based industrial supplier) - they have a fair range of big profiles and appear to have an outlet down under and whilst not always the cheapest you might get much cheaper shipping.
    Thanks Voicecoil. I'll have a look for them.
    EDIT: I just tried to register and they don't sell to individuals.....I can't win.....
  2. #42
    Misumi USA appears to be great and happy to deal with small orders.
    Misumi near Australia (I think Singapore) only want to deal with businesses.
  3. #43
    Quote Originally Posted by Sterob View Post
    Its basically a 6040 sized bed but the frame will be larger so the tool will reach the whole bed area ( at this stage. )
    That's ridiculous overkill and a complete waste of money. I've built many machines this size and larger using 45x90 using the "L" design gantry and they are plenty strong enough for a machine this size. You'll get away with a much smaller profile and 80 x 120 would still be massive overkill for a machine this size.
  4. #44
    Yes, but 80 profile doesn't have the 45mm spacing of the slots.
  5. #45
    Maybe I could drop the whole build back to using only HD 45 extrusion?( 45 x 90 for the sides and gantry.)
    Would be alot cheaper and there are a lot more size options...... as long as it would stiff enough.
    Can do some simulations in Fusion I guess.
    I am a little concerned about attaching 45 extrusion to side plates using just the 2 holes in the centre. That does not seem the best idea.
    Is there any way to utilise the square hole in each corner?
Name:	Bosch Rexroth 45 x 90.JPG
  6. #46
    You don't seem to believe what I'm saying to you regards the strength so this will be my last post on this subject because I'm clearly not getting thru so not wasting any more time saying it. However here's the answer to your worrys regards bolts, which by the way are 12mm with a holding force more than enough, even without the pockets.
  7. #47
    Sorry Jazz....Just lots of things to think about and my goal posts keep on moving....
    I remember you mentioning that now.
    It just that Extrusion is crazy expensive here and if the basic foundations are wrong, it carries all the way through the machine.
  8. #48
    If it's that expensive then why not use steel and find a machine shop who can surface the faces.? It might be cheaper and end up stronger.
  9. #49
    Yes, thats an option as well.... I will keep that in mind, thanks.
  10. #50
    If you're set on using 45mm spacing stuff, there's always this! https://kanya-uk.co.uk/product/e01-1...rusion-90x135/
  1. Complete soundproofing setup for 6040 sized CNC
    By suspension in forum Classified Ads, Buy, Sell & Swap
    Last Post: 24-03-2018, 05:36 PM
  2. BUILD LOG: Gantry style CNC mill
    By giladv in forum DIY Router Build Logs
    Last Post: 22-03-2018, 08:23 AM
  3. Questions on using a moving gantry style mini-mill...
    By Davek0974 in forum Machine Discussion
    Last Post: 13-07-2016, 06:07 PM
  4. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  5. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
