21-02-2020 #6
"Required rigidity" is quite subjective. Certainly this design is well tested around here and provides "enough rigidity". You have two options at this point; copy something that works, or do all the maths and arrive at your own answer based on what you want to cut and your machine design.
There's a mechanical deflection spreadsheet around here somewhere, probably in the gantry design threads. You can use that to see how different dimensions on the L will affect the maximum deflection given a standard set of conditions like gantry span and weight of the Z axis. Because your width is smaller than mine if you used the same profile you'd get less deflection for the same Z weight.
I suggest you go and have a play with the spreadsheet to discover the relationships. Ultimately it depends on what tolerances you're happy with.
Complete soundproofing setup for 6040 sized CNC
By suspension in forum Classified Ads, Buy, Sell & SwapReplies: 0Last Post: 24-03-2018, 05:36 PM -
BUILD LOG: Gantry style CNC mill
By giladv in forum DIY Router Build LogsReplies: 22Last Post: 22-03-2018, 08:23 AM -
Questions on using a moving gantry style mini-mill...
By Davek0974 in forum Machine DiscussionReplies: 183Last Post: 13-07-2016, 06:07 PM -
Garage CNC - A gantry style machine design
By fandango in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 21-03-2014, 01:38 AM -
Truss style Gantry
By D.C. in forum Gantry/Router Machines & BuildingReplies: 28Last Post: 15-12-2012, 07:23 PM
