    Quite happy to follow in someone else footsteps...lol
    I want to see if there were any examples of 6040 size machine using L Gantries, but none have surfaced yet.
    Thanks...will check out the spreadsheet.
    I assume I could use fusion to get a idea of distortion under certain loads?
    WIll have a play with that as well.
    Quote Originally Posted by Sterob View Post
    Here's a 6040 sized machine and it easily cuts everything up to Aluminium. I've built several machines this size which cut everything from MDF to Carbon fibre parts for RC cars and Clocks which require fine tolerences so don't worry about it being upto the job.
    The best profile to use is 45 x 90 because it makes things easier with mounting ball-screws. However, 40 x 80 will work on smaller machine but you'll just need to make plates to mount BK/BF bearings on for ball-screws.
    That appears to be one short cut I won't be able to use as the supplier to have tenatively chosen does not supply 45 sized extrusion., only 40 and even that has to come from the other side of the country.....
    Some googling has found 1 or 2 suppliers that use 45 but the quality is unknown.
    I'll either have made adapter plates for each bearing block or mount the bearing in another way.
    Look for Bosch Rexroth or equivalent BR style profile. 10mm slot
    Do you know if there is any significant price differences between BR and for example Item profiles? Both are offering 45 series profiles with 10mm slot.
    EDIT: Just checked and Item does not offer 45 series profiles, only 40 or 50 series. I got a quote from Item on 1000mm long 80x160 profile: 220 Euro. That seems expensive, dont you think? I need to get a quote also from BR.
    Skickat från min SM-A530F via Tapatalk
    Thanks Jazz, I found a supplier of Bosch Rexroth in Perth, 200 km away.
    They also supply other brands so have asked about them as well.
    Hi Steve,
    Please would you let me know their price for Bosch Rexroth 45 x 90 Heavy profile once you know it.
    Whereas it's dead simple going online 24x7 to get accurate pricing for this kind of thing in the UK, as I'm sure you know down here it's like pulling hen's teeth and requires phone call(s) or email(s) requesting pricing, and I haven't the foggiest idea what these things might cost down under and how badly "they" would rip off us buyers.
    Thanks, Andy
    Quote Originally Posted by AndyGuid View Post
    Hi Steve,
    Thanks, Andy
    Will do Andy.
    Have requested some 'tenative' pricing as I don't exact dimensions yet.
    Whats the preffered method of attaching Bosch Rexroth Extrusions to Gandtry plates?
    With Item24, its easy....4 or 8 bolts threaded into the end of the Extrusion...
    I see many connection methods in catalogue, but nothing seems to address this issue.
    A single bolt in the centre doesn't seem to be it.....
    Steve
    Hi Steve,
    Thanks, Andy
    Google KJN aluminium I have no problems at all you need to configure to get the right price, remember VAT.
    I'm very lucky because I live within 5 miles of them, they cut all my extrusion and cnc drilled it for me.
  1. Complete soundproofing setup for 6040 sized CNC
    By suspension in forum Classified Ads, Buy, Sell & Swap
    Last Post: 24-03-2018, 05:36 PM
  2. BUILD LOG: Gantry style CNC mill
    By giladv in forum DIY Router Build Logs
    Last Post: 22-03-2018, 08:23 AM
  3. Questions on using a moving gantry style mini-mill...
    By Davek0974 in forum Machine Discussion
    Last Post: 13-07-2016, 06:07 PM
  4. Garage CNC - A gantry style machine design
    By fandango in forum Gantry/Router Machines & Building
    Last Post: 21-03-2014, 01:38 AM
  5. Truss style Gantry
    Last Post: 15-12-2012, 07:23 PM
