	06-03-2020 #1Hi All,
 I bought myself a new motor (0.55kw, dual voltage, 4 pole) for my Myford lathe and to test it I thought I'd hook it up to my Chinese 2.2kw VFD that I bought for my CNC router. I have used the VFD with router spindle and it works fine so I know that the VFD is functional. I swapped the links in the motor to make it delta configuration and wired up U,V,W and Earth to the VFD and powered up.
 On the VFD I pressed the Run button and slowly started to increase the frequency. The motor started to turn slowly but as I increased the Hz the shaft slowed and eventually stopped turning altogether. The thing I found most wierd was that the motor sounded like it was getting faster as I increased the Hz on the VFD but the shaft speed didn't reflect that. I would say that it reaches about 50-60 RPM (not Hz) before the shaft speed drops off again.
 The VFD is completely unaltered from new, I haven't changed any of the parameters. I have looked through the manual and I can't see that any of the parameters would have an effect on the symptoms that I am experiencing - but I'm certainly not sure of that. I have tried swapping a couple of the phase wires around, rechecked all my connections, turned it off and back on again (a 25 year career in IT - can you tell?), checked the ribbon cable to the VFD's control panel, and re-wired it all up again in case I had a brain-fart but I am still getting the same result. Anyone know where I might be going wrong - am I doing something properly daft? Or could I have a duff motor?
  Servo motor and inverter dilemmaBy dazp1976 in forum Motor Drivers & ControllersReplies: 2Last Post: 11-09-2018, 11:02 AM
  Last one of the 2017 Lathes - 1.5kW 3phase motor with inverterBy komatias in forum Manufacturer NewsReplies: 0Last Post: 02-01-2018, 10:56 AM
  Lenze 8200 VFD Inverter - Spindle motor not movingBy Fgc in forum Spindles & Drive MotorsReplies: 7Last Post: 13-11-2017, 02:34 AM
  Machine Slow on CurvesBy swisscheese in forum Computer SoftwareReplies: 31Last Post: 12-04-2014, 12:49 AM
  Forum SlowBy pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM
