    Under the 2D operations drop-down menu, I would use "Contour" for that. I'm assuming that you have already created a "setup" which defines the work coordinates? For something like this I would set Z=0 to the bottom of the work. Then when you create your cutting operation, select the bottom contours of your tiles and set the bottom cutting height to, say, -0.2mm, depending on how flat your spoil board is. You can also specify tabs to hold the pieces in place while cutting.
    To be honest, a reply like this could ramble on for pages specifying a whole raft of things to set but one of the key bits of F360 is knowing which settings you can ignore and leave as the default!
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. #2
    Thanks for such a quick reply - frankly I think I'd benefit from your rambling a lot !
    I'm still thinking through how it's easiest to create tabs - any advice would be very welcome ... I find it odd that we don't have a software stream in the forum, seems to be that's where a lot of the issues lie.
    Fusion 360 seems amazingly functionally rich - but in terms of user friendlyness I think it should be written FU-sion 360 :-)
    Quote Originally Posted by Britannicus1 View Post
    There is a CAD & CAM section under 'Computing' but no specific F360 thread. Might be time to start one?
  1. Fusion 360 question
    By Britannicus1 in forum General Discussion
    Last Post: 31-01-2020, 02:33 PM
  2. very basic cad cam software
    By charlieuk in forum General Discussion
    Last Post: 23-02-2015, 04:36 PM
  3. The ideal CNC machine for my (basic)needs?
    By mark84 in forum Machine Discussion
    Last Post: 12-03-2014, 10:56 AM
  4. NEW MEMBER: Basic 3d milling
    By proddy in forum New Member Introductions
    Last Post: 08-06-2012, 12:11 AM
  5. Which Basic Lathe
    By graysclassics in forum Milling Machines, Builds & Conversions
    Last Post: 06-07-2011, 10:39 PM
