Thread: 'Built in' Adjustment
One thing I've done to minimise the total slop is to drill all clearance holes to minimal size and then enlarge as required. It's a tedious process and you will need to decide whether it's worth it considering the amount of repeated assembly/disassembly required.
Wherever possible try to design in a way that you can adjust only one parameter at a time and not have to undo one adjustment to get at another. That's much easier said than done.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Z AXIS Adjustment design Help
By RobC in forum General DiscussionReplies: 0Last Post: 11-04-2019, 04:50 PM -
Have you built your own CNC plasma table ?
By adscnc in forum Opportunities Available & SoughtReplies: 0Last Post: 15-09-2016, 02:13 PM -
Start of a new built.
By Tanky_Turk in forum Gantry/Router Machines & BuildingReplies: 10Last Post: 06-03-2014, 09:26 PM -
WANTED: home built cnc
By japcarmaniac in forum Items WantedReplies: 1Last Post: 24-04-2013, 02:35 AM -
Milling machine yaw and pitch adjustment
By Golfer4588 in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 16-01-2012, 03:02 PM
