16-02-2020 #1
Ok I'm curious to what cutting area suits people best.? Obviously we'd all like the largest cutting area possible but the reality is most of us have limited workshop space. So what I'm really asking is what cutting area suits your needs and space best.?
This can be either a Router or Mill type machine. So here's a few questions.
#1 Machine type, Mill or Router (no lathes)
#2 Cutting area X, Y, Z
#3 Ideal overall footprint size W,D,H (or space to fit into)
#4 Floor standing or benchtop.
#5 Material most likely to be cut.
Thanks.
16-02-2020 #2
#2 Cutting area X 300min, Y 200 min, Z 300min
#3 Ideal overall footprint no greater than an 8 foot cube (Like the mix of metric for small & imperial for big? I really do think that way :D )
#4 Floor standing
#5 Material most likely to be cut, Stainless, Titanium, Tool Steels and Aluminium with a side of Engineering Plastics and Composites ;-)You think that's too expensive? You're not a Model Engineer are you? :D
The Following 3 Users Say Thank You to magicniner For This Useful Post:
17-02-2020 #3
#1 Router
#2 X,Y As much as will practically fit onto #3. Z 60mm max.
#3 1m x 1.3m
#4 Benchtop (I'll need to move it a long way soon-ish)
#4 Plywood, hardwood, some acrylicAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
The Following 2 Users Say Thank You to Kitwn For This Useful Post:
17-02-2020 #4
Two areas of interest:
Mechanical
#1 Mill
#2 X,Y, Z : 500x200x150
#3 1m x 0.8M x Z=?? (fit in the shed)
#4 Bench-top
#4 Ali, brass, mild steel
Electrical (PCB, etc)
#1 Router : High speed spindle.
#2 300 x 300 x 50
#3 0.8M x 0.8M x Z=? (fit into shed)
#4 Benchtop
#4 FR4, 35um copper cladding, enclosures - ali, plastics
The Following 2 Users Say Thank You to Doddy For This Useful Post:
17-02-2020 #5
Like Doddy, two areas of interest:
Chunky stuff
#1 Mill/machining centre /whatever
#2 X,Y, Z : 500x250x200
#3 0.9m x 0.8M x Z=??
#4 Bench-top
#5 Ali, brass, mild steel. composites
(nearly finished woohoo!)
Sheet stuff
#1 Router
#2 X,Y, Z : 2400x1200x150
#3 3m x 1m-ish x tall as necessary
#4 floor standing, vertical format
#4 MDF, plywood, ali, composites, plastics
The Following User Says Thank You to Voicecoil For This Useful Post:
17-02-2020 #6
#1 heavy built router
#2 ~800x450x150
#3 ~1200x800x400(height not critical)
#4 bench top
#5 aluminium bias (speed feed) with suboptimal for wood
My needs are a bit odd. Need to cut fairly large sheets of liteply for model making
Also fairly small sized pieces of aluminium with good finish and accuracy.
Good luck with what I guess you are planning. Maybe a well made 6040 size machine would prove popular.
The Following 2 Users Say Thank You to routercnc For This Useful Post:
18-02-2020 #7
Router, everyone wants bigger right?
I want a 3m*2m
My machine, If I rebuilt it now I would make sure I have 1.8m travel * 0.9m, but I actually have 1.2m * 0.7m, 0.8m if I convert to belt drive.
Height 5cm seems good I gave myself 9cm and now am adding 3.6cm of MDF to reduce the travel.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-02-2020 #8
21-02-2020 #9
That would be the ideal size for me; does such a machine exist? and yes, I'm a model engineer so needs to be cheap!
Brian
21-02-2020 #10
Not sure which size your referring to but please look at the first post and answer the questions. This would help me greatly because you are the perfect person to answer because your brand new to CNC.
Oh and to answer your "Does it exist" question then it probably does but if not then we can make it exist, that's what we do best.!
A couple of beginner questions... Profile sizes and cutting area size.
By joe.ninety in forum General DiscussionReplies: 12Last Post: 28-01-2020, 12:16 PM -
trying to keep the machine close to the cutting area
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 7Last Post: 04-12-2017, 11:22 PM -
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
Wanted - Regular work for reliable machine shop in Northants/Kettering area
By Narkedat90 in forum Opportunities Available & SoughtReplies: 4Last Post: 06-04-2013, 04:09 PM
