Thread: Help, Cutting problems
17-02-2020 #13
The tool was damaged Jazz, brand new as well I bought 3 of them other 2 perfect.
Was causing that line effect.
The real issues I was having is the Z axis was bottoming out causing it to lose a step with certain tools (Short ones) as it hit the ballscrew mount. Why my 2d engraving was fine was never bottoming the axis.
My AM882's on my X&Y fire fault protects if they hit the ballscrew mounts only happened when my dodgy home switch soldering came a cropper lol.
But the Z can bounce off the mounts all day long guessing my motor isn't powerful enough to trigger it only a puny 1.2nm, it's getting swapped for 1.8nm ones just because I'll have a couple of spare and I bought them new, the 1.2nm one is 2nd hand and well worked.
My solution add another sheet of MDF to the bed to raise it another 18mm I might add 2 to raise it 36mm. Tomorrow I shall test my theory but well it was bottoming out on the mount and I was losing steps on the Z so I think it's a no brainer.
I have 9cm of travel so can afford to lose some.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
Cutting problems on a gerber
By martin54 in forum Machine DiscussionReplies: 2Last Post: 01-06-2013, 09:07 PM -
Big problems with cutting HDPE can you help?
By Nathan_Partington in forum Machine DiscussionReplies: 2Last Post: 11-05-2012, 09:44 AM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
