Thread: Help, Cutting problems
24-02-2020 #16
Just a little update if anyone else with a DDCSV comes across this post.
You have to set the post processor to fanuc in Fusion 360
You need to turn helical moves off for it to work properly.
I had a dodgy coupling which made things much worse, once I replaced the bad couplings and changed the post processor in Fusion everything started working better.
Now I need to program my ball nose mills into Fusion I think and play with the stepover to dial it in.
From what I read set it to 1/8th the diameter should be fine.Last edited by Desertboy; 24-02-2020 at 04:23 PM.
Mach3 Problems problems problems.
By ECCO in forum Artsoft Mach (3 & 4)Replies: 18Last Post: 09-07-2016, 10:07 AM -
circle cutting mach 3 problems help please
By millmateuk in forum Artsoft Mach (3 & 4)Replies: 1Last Post: 13-06-2013, 07:04 AM -
Cutting problems on a gerber
By martin54 in forum Machine DiscussionReplies: 2Last Post: 01-06-2013, 09:07 PM -
Big problems with cutting HDPE can you help?
By Nathan_Partington in forum Machine DiscussionReplies: 2Last Post: 11-05-2012, 09:44 AM -
NEW MEMBER: MDF Problems
By MrWiz73 in forum New Member IntroductionsReplies: 4Last Post: 31-12-2011, 12:39 AM
