Thread: Converting an axis to belt drive
18-02-2020 #7
First, convert to a belt drive from what.?
HTD is the belt to use. Pulley size will depend on how you do it and the resolution you want. Don't think because it's a 5mm pitch belt that's the actual pitch or linear movement you'll get because it's not. The diameter of the pulley x Pi is the actual pitch you'll end up with. So depending on how it's done and pully size you could need a gear ratio to give the resolution you need.!
6m X axis Rack and pinion or belt drive?
By charlieuk in forum Rack & Pinion SystemsReplies: 6Last Post: 02-07-2020, 01:22 AM -
BUILD LOG: belt drive to ballscrew drive changeover advice required
By marbles in forum DIY Router Build LogsReplies: 4Last Post: 14-02-2020, 02:14 AM -
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
any one know where to get a belt drive convertion for x2
By Scott in forum Sieg Milling MachinesReplies: 15Last Post: 27-09-2010, 08:44 PM -
Re: Standard Drive Belt Size ?
By HS93 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 18-05-2009, 03:30 PM
